pcs crusher flares and body armor installed
replacing a broken plastic flare when you snag a tree at least 150
dupi color for the scratch on metal flares 8 bucks
its all in what you want to spend your dime on. for me i love them and would never spend money on a dang system (radio) in my rig. i see thousands of dollars go down the drain all the time on that stuff.
sorry i don't think i will but psc did. and it was a yj i was mistaken. you know it happens even to the best of us lol. i would post up pic but i don't know how to post up other peoples pictures (i am not a computer guy lol). and thanks i love the look as well as the benifets.
as for the install of these they went pretty smothly. my main hickup was the nutsert tool had to small of a head on it and would push the washer back up and i would round off the bolt head. so my solution was to take a bigger nut that fit over the bolt head and i welded it it on there. no more problems after that. the sheet metal on the jk is just so thin and almost worthless. i feel like plastic would have been stronger lol.
overall i am again happy with the fit of these. the front part of the armor is my only complaint it has about a 3/16th inch gap on both sides (only visible if you look down on it. it really strengthens the side of the jeep and will help protect it till i order up some rocker knockers. for now my rubi rails will do the trick. here is a few pictures for you and again sorry for the low light but i didn't finish till after dark. i had to use the shop lights again.
I had the same problem with the armor. I bought some longer bolts and put a fender washer and nut on the inside of the fender. It wasn't easy but I got the armor to sit flush.
What backspacing are your wheels? Do you have a direct front or rear shot? Would like to see how stubby the fenders are, as there are some laws here we need to abide with.
my wheels are 17 x 9.5 with 3.5 bs. the fenders are stock width basically. you get a little more coverage on the back by the door but tapper in on the front some. my tires are about 2 to 3 inches out from the fender. before with the stock flares they were 3 inches out.
the only flares that i have seen with more coverage are the exon wides. (2" more than stock) and that would still leave me a inch outside the fender. my setup is just really wide most with 4.5 bs and a 8" rim would have much less outside the fender if any. if you are happy with a stock flare width psc will be a little better.
