Painting the inside of my hard top black
#22
I wouldn't use the bed liner in a can for your floor. It seems like it would take alot of cans (@ $8.99 each) to equal the same thickness as what a $100 gallon of Hurculiner would do.
If you're really serious, let's meet up to get both our Jeeps done at the same time. I've been trying to find time to do my floor with Hurculiner ever since we went to 7 Springs and my Jeep ate dust for 6hrs and I had to rip the carpet out.
#26
Not sure of the cleaning factor as it's a rough texture but you could prob just use a wet rag if you got some other liquid on it or something. If worst came to worst, you could always just spray another layer over the problem
#27
So why do you use the spray bedliner on the top panels and not Herculiner? Is the spray on more rubbery? Or is it gritty like Herculiner?
I want to do mine but not sure if it wouldn't be easier just to Herculine the tub and top at the same time.
#28
You're supposed to roll the Hurculiner on whereas the hard top needs a more controlled, detailed application. For all intents & purposes they are the same. The Duplicolor brand though is more gritty than rubbery. I plan on doing the tub pretty soon here so maybe I'll compare the two and do a top coat of hurculiner on the hard top.
#30
Thermal resistant paint? Where do you get that from? Or is this another ball bearings for the gas tank mod?
I gotta do something my tops where super hot today even with the AC running.
