Our JK's with 2.5" BB Installed
Me and my buddy each installed the Teraflex 2.5" BB on our JK's. Here's a few poser pics Next up is our Shrockworks Midwidth Bumpers and then some 35" tires. I'll post pics once they are installed.
Hey guys that looks good. I have a question for yall though. On the white one did you also put a 3/4" spacer up front. I am looking at this same set up but before I ordered just wanted to see if I needed to order one or not. Also was it fairly easy to install?
TIA
Andrew
TIA
Andrew
It was super easy to install ... we followed the project-jk writeup which made it real simple. We did have to use spring compressors on the front springs and I don't see how you could install it without them. I did not use a 3/4" spacer in the front but I may once my Shrockworks Mid comes in we'll see how much it sags.
The kit came with everything we needed so that was pretty sweet.
I'm interested in why it is some people have to use spring compressors? Were you not able to get the front to drop enough to pull/replace the springs? I did this install myself and was able to get the driveshaft (auto trans) to drop enough to allow the easy release and fairly easy replacement (used a 2x4 and heavy screwdriver for leverage) of the springs up front.
