Old Man Emu - Flex
Just installed the OME 2" lift that I bought from David at Northridge. I'm really satisfied with it so far. Here are some shots that I took during a test run:
![](http://inlinethumb19.webshots.com/35538/2971269620102055478S600x600Q85.jpg)
![](http://inlinethumb30.webshots.com/16605/2626863260102055478S600x600Q85.jpg)
![](http://inlinethumb40.webshots.com/40743/2623134040102055478S600x600Q85.jpg)
![](http://inlinethumb33.webshots.com/4192/2760859080102055478S600x600Q85.jpg)
![](http://inlinethumb47.webshots.com/16174/2674260970102055478S600x600Q85.jpg)
![](http://inlinethumb23.webshots.com/42134/2100369290102055478S600x600Q85.jpg)
![](http://inlinethumb24.webshots.com/37463/2030809550102055478S600x600Q85.jpg)
Moved rear sway bar links to front and installed new ones in rear
![](http://inlinethumb32.webshots.com/42207/2559054420102055478S600x600Q85.jpg)
Rear brake lines were stretched to the limit during full flex
![](http://inlinethumb43.webshots.com/35306/2761039850102055478S600x600Q85.jpg)
![](http://inlinethumb36.webshots.com/10403/2364343420102055478S600x600Q85.jpg)
![](http://inlinethumb08.webshots.com/33479/2766545240102055478S600x600Q85.jpg)
![](http://inlinethumb49.webshots.com/40560/2835762180102055478S600x600Q85.jpg)
It's the 619 front coils and 618 rear coils along with the N196 front shocks with the N198 rear shocks. I believe this is the Heavy Duty kit. I bought it from David at Northridge 4x4. It was missing the 1/2" front coil spacers that was mentioned would be included with the kit in the writeup. I'm also waiting for the Full-traction front and rear adjustable track bars.
Call Teraflex and get some rear break line extensions. I used the extensions from their 2.5" BB kit and they work perfectly. They will sell them to you direct pretty cheap.
