Oh Noes, I SHAT, where's my handles?
Well. like the title say's:
List of things purchased:
htp://www.mcmaster.com/#hook-and-loop/=8iqqeq
9273K113
(Same as 9273K11)
All-Purpose Nylon Hook and Loop 1/2" Width X 5' Length, Adhesive Back, Black
In stock at $5.24 per Pack
htp://www.homedepot.com/h_d1/N-5yc1vZ1xhc/R-202196703/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Black Plasti Dip
Model # 11603-6
Store SO SKU # 250084
htp://www.homedepot.com/Building-Materials-Plumbing-Pipe-Fittings-Valves-PVC-Fittings-PVC-DWV-Pipe/h_d1/N-5yc1vZ1xhcZbbm6/R-202017947/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Charlotte Pipe 3/4 In. x 2 Ft. Sch 40 Plain End Pipe
Bought everything.
Took off adhesive to the Velcro backings, stuck A and B together.
Cut 2 Pieces PVC pipe to 6.25"
When the Velcro is stuck together, I cut a center line between the two to form an "I" shaped (split in half down 8" Approx.), then left 6.25 inches untouched and split another 8 inches on the end of the strap. You'll need to do this in order to make "Oh Noes, I SHAT, where's my handles" parallel to the roll bar.
After that, I dipped the pvc pipes inside of the rubber dip. Re-did it for another coating half hour later per the instructions. called it a day, and it all came together.
It feels and looks like rubber handles. Very sturdy.
9273K113
(Same as 9273K11)
Black Plasti Dip
Model # 11603-6
Bought everything.
