The Official " Show me your JK on 15 inch Wheels " thread
#521
Hi all I am thinking of running Ultra type 164 with Size: 15x10, Offset: -48mm and Backspacing: 3.66, and as much as I have read about backspace and offsett I am still kind of confused. Basically my question would that wheel rub or have any problems? I want something that I can just put on and not have to worry about other mod's to make them work properly.
#522
#523
2010 JK 3" lift with 35x12.5r15s
MB Razors and General Grabber Red Letters
Shout out to DTD for the advice!
#524
Well, you can use the Rock Krawler tie rod. It uses the stronger drag link Pittman arm joint on both ends of the tie rod. I use the synergy tie rod. It only hits the inside of the rim when I push it against a rock or something. I'm using American racing AR 23 wheels. 15x8 with 3.75 back space. I believe the Rk one is a better fit, but costs more because you need to buy 2 drag link ends.
#525
#526
#527
Those Gobi's are sweet. Expensive, but sweet! Ill be needing one eventually, hauling around a Great Dane and Chocolate lab along with camping gear leaves little room inside.
#529
#530
Has any one tried or researched Aero wheels? They make wheels for Nascar and other roundy round stuff. Most of their series are ultra light weight non DOT approved. But the Series 50 is a bit heavier duty. I love the look and I want. Any words of wisdom?
