The Official " Show me your JK on 15 inch Wheels " thread
#484
We've been running 10" wide wheels on our past 3 Jeeps. Main reason is that I wanted the additional width, plus I think the 12.5" wide tires flex better on a 10" wide wheel. I know some say that you'll pop a bead on the wider tire, yet we run ~12PSI and have never (knock on wood) had a blown bead.
I attached a couple of pics of our 15x10 wheels.
#485
15x10 Pro Comp's w/ 3.75" BS
I have about 3" of lift from using Rubicon 19/60 springs and a 1" spacer in the front plus 1/2" in rear.
Here are some pics without the lift. It would have wheeled fine with bump stops to keep the tires from tearing things up. The trimming really opened things up!
#487
#489
How do you like the Rubicon express lift? I was thinking of getting the spring and shock kit.
running 35" BFG KM2 on 15x8 MB wheels I am running this combo on a 2.5" Rubicon express coil lift. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=542374"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=542375"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=542376"/>
#490
My 15" Dia 8" Wide Level 8 Punch wheels with -19mm offset wearing 33" x 12.5" Duratracs. Brake caliper clearance in front is OK, about that of a piece of Trident gum. Rear is pretty tight, about that of a piece of Wrigley Spearmint gum. May eventually shave a little off the rear calipers if I get inspired one day.
