Off Road Evolution EVO Rock Star Skids
#24
Hey Mel,
1. Can these be used with a Tera Flex 2.5" Coil lift?
2. With the above lift will I run into brake line problems? ..... or other problems?
3. I noticed someone else ask about downward travel limitation....... I'm sure that I'm just missing something elementary, but maybe someone can explain this.
I love the fact that they're higher and protected, and stoutly made![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
#26
Your right..... that makes sense.......
So does that mean I'll need shocks with longer down travel to take advantage of this?
I'm just about to order the Tera Flex 2.5" Coil lift with shocks and I'd rather order it without the shocks if I'll need to have longer shocks for the rear.
Here's my other questions:
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
#27
These along with the front EVO control arm skids are right at the top of my list of upgrades behind my 5.38 gear install.
I only have one question... How much does it raise the sway bar link mounting location?
#28
#29
I'm not sure about that... from the pictures it looks like it raises the lower mounting point for the sway bar links. If you didn't adress this than you could easily reverse the sway bar and cause some damage. If the bracket raises the mounting point 1.5-2" then I would be good to go with my current set-up.
EDIT: I just notice that the pics sm_rubi posted of his are different than wayoflife posted. From the pic in the op it looks like the lower swaybar link is raised and on sm_rubi it does not...??? Also, form the picture of the product on EVO's website it looks like it does have a raised mounting point as well.
#30
