New Rockhard rear bumper...
none. of course when the unit vibrates it has a different noise but not squeeks or clunks. the latch also cuts down the vibrations. wish i didnt break my camera, id send some pics
this is the type of latch i used. i put it on the front of the tire carrier and bumper. you'd need to weld it so you dont hit the mechanism in carrier. the closer to the edge (drivers side) the more leverage it will have. i also made sure it cleared the handle to the highlift jack
I already had the washers to decrease the front/back travel/force of contact between the carrier and the tail gate. Don't know how this would or wouldn't help as it was done this way from the start.
Can you borrow your favorite neighbor's camera and post this mod? Some of the rattling must be from up and down movement on the bumper, so I'm thinking you attached it so the tire carrier is pulled down onto the bumper tighter. Is this accurate? Did you drill the bumper and carrier, weld it, or both?
hope this helps. i used 1/2'' bar drilled and tapped then welded to the tire rack and then the bumper. by doing this im able to have enough steel to bolt through without running the bolts into the carrier latch.
I just installed mine a little while ago and I took measurements of the rear ride height before and after the install. The rear ride height dropped only 1/4".
For all you with the "drumming" sound. You need to take out one of the shims under the bottom carrier bearing and move it to the top. Once in position there needs to be a load on that rubber bumper. If it's drumming there isn't enough load.
No rattle from my latch either. Loosen up the stricker post with a Torx wrench and move it towards the tailgate some.
