New KMC XD series Rockstar and Pitbull Rockers
Check out my new rims and tires.............
Rims = KMC XD Rockstars (8.5x20)
Tires = Pitbull Rockers (37x13.50x20)
Here are a couple shots, check this link: Flickr page for before and after...
Also.. you may notice in the before and after, that I added a Rancho bumper... I created an install video that will be published soon.
Yeah, its the Rancho... and the install was interesting, like I stated above, I created an entire video documenting the process. I should be done with the edit this week, I will post a new thread then...
I recommend watching before buying... just trust me.
Chalk Test:
Find a straight flat road where you can start and stop saftley.
Use chalk to draw a line across your tead surface from top edge of shoulder block to top edge of shoulder block.
Drive foreward about 100 feet, get out and see if the chalk line is gone. If there is some left on the outer edges then decrease the pressure. If it was gone on the first test increase the pressure (about 2 psi at a time).
Goal is to find the highest pressure at which the chalk line completley disapears.
This will provide maximum tread life assuming you also balance and rotate regularly.
