NEW - IPF 920H4 JK Headlights!!
#41
most likely, australia but, i can try to find out for sure.
that's what i was thinking. to the best of my knowledge, northridge4x4 is the only one who should be getting these so i'm not sure where you could have gotten them from.
#42
okay, so we've been testing these lights out in the super dark desert all weekend and here's what i can tell you. being that these lights are plug-n-play and therefore use the same watt bulbs, it would be difficult for them to be "brighter" than the stock headlights but, having said that, the bulbs are definitely a lot whiter and more importantly, the lenses do an amazing job of providing a much greater and even spread across the road. of course, this is compared to the stock lights which only puts out a narrow band of light out in front of you leaving everything in front and behind the band in the dark. needless to say, with these headlights, you no longer have to use your fog to help fill in the gaps.
now, i should note that i didn't have time to set the headlights to where they should be before heading out on our trip. and, because of this, i found that the were a bit on the high side but even at that, the low beams still looked super impressive. however, because they were on the high side, the high beams felt a little too high for my taste and road immediately in front looked a bit on the dark side. once i make some adjustments, i suspect that the high beams will look a lot better and expect that the low beams will look even better too. anyway, i just thought ya'll might appreciate a heads up on things and i'll post more info on these after the adjustments.
#48
#49
The kit is not yet available and is not listed yet because of that. Northridge has stated WHEN they get the kits assembled and in they will post a new thread here with them in it. I dont have a clue what you "ordered" but it wasnt these.
#50
They are not available at Northridge4x4.ca yet either....Stan told me he will notify me when they arrive & price!
