NEW - IPF 920H4 JK Headlights!!
#131
I have these headlights installed but I am having an issue with them staying lit. The problem seems to be in the harness they supply...if I shake it around enough and jiggle it I can get the lights to come on most of the time, but otherwise I am often left driving with only 1 light.
What gives? And what can I do to fix the issue? I've had these installed for a little over a year, is there any sort of warranty?
Anyone else have this issue and been able to fix it?
Thanks in advance
Thanks in advance
#132
This seems to be a known problem with the connectors on the harness plugs. They don't snap in place. Having read this prior to installing mine I just add a zip tie around the bulb connector to keep it from popping off. Never had a problem.
#133
#134
Same here with issue of harness not popping in ecen after triming the tab....i put some die electric grease then took two zipties forming a x around plug then taped them up to prevent zip ties from coming loose...no more problems
