New Axle For M101 or M116 Trailer
All,
What size axle did you put on your M101 or M116 trailer? I would like to get one that would be about the same size as a Jeep JK. I plan on building my own box on the trailer frame as the military box is way to big.
Thanks
Thanks
I used a 3500 lb axle with 2000 lb springs. I have a very light trailer and it still rides a little stiff. I went with the oversized axle to get off road durability.
I used the axle from my M416 with wheel adapters to widen and so that I could run the same lug pattern as the JK. Same with the springs, original M416 springs. Except I removed a couple of leafs to soften the suspension, and added gas shocks. Wouldn't advise using regular trailer springs, they length is too short to perform off road.
I got mine from a-dapt-it usa. Copy and Google that and you will find their website. Not sure if I can post a link without getting into trouble.
