New AEV 2012 Procal's are in stock
The difference is that the AEV isn't technically a "performance chip" that alters programming of the engine. The problem with the Superchips and the other performance chips is the harder to crack engine codes in the new ('11-12) JK. I will be buying a Procal to correct my tire size because my speedo is way off, but it's not going to give a huge performance gain. It will put the shift points back to stock levels, so the tranny won't hunt for gears as much, but no real performance gain.
Sponsoring Vendor
I am sorry I didnt realize this was a question
it does everything the same for the 2012 as it does for the 2007-2011 but also it corrects the computer so you can change gears in your 2012 so it doesnt go into limp mode.
As well as Tire Size, Axle Ratio, Running lamp settings and TPMS settings.
David
we kinda know what theyd look like ! if they dont do much
it wouldnt matter what the box looks like !
what it does for the 2012 should be a standard question ? besides adjusting speedo and shut off tpms light !
David
