New 2012 2-door Cosmos Blue Sport minor Build
I couldn't get used to it because there is a slight resistance off the line. I've been driving manuals for 25+ years; it was unnatural. Try disabling it and see if you get increased flat terrain rolling. The moment I disabled mine it was like night and day difference. It felt like I gained 10 HP, the Jeep was more peppier and it just felt right.
HSA Off
If you wish to turn off the HSA system, follow this
procedure:
1. Start with the engine off and vehicle in PARK (automatic
transmission) or NEUTRAL with clutch out
(manual transmission) with wheels straight. Apply parking
brake on manual transmission vehicle.
2. Start the engine.
3. With the engine running, the brake applied, and the
clutch out, rotate the steering wheel 180° counterclockwise
from center.
4. Press the ESC OFF switch four times within twenty
seconds.
5. Rotate the steering wheel 360° clockwise (180° clockwise
from center).
6. Cycle ignition switch OFF then ON.
7. If the sequence was completed properly, the “ESC
Activation/Malfunction Indicator Light” will blink several
times to confirm HSA is off.
Steps 1-7 must be completed within 90 seconds to turn off
HSA. Repeat steps 1-7 to re-enable HSA functionality.
Do exactly as it says; it will disengage.
procedure:
from center.
seconds.
from center).
