My turn to build Q-forms
Rutdigger was actually putting another layer of fiberglass and resin on when i stopped by on my way home from work. Did a test fit with the sub, and no clearance issues at all, fits perfect. Still a lot to do to get to the point of enjoyin them.
After we decide if we like the look or not then we glass the shirt and let it get hard. Depending on what you have planned with the filler will depend on how many layers of actual fiberglass you put on top of the shirt.
I think we will be able to get away with just one layer of fiberglass over the shirt, then filler, prime, more filler, sand till our back hurts, then paint..lol.
Very nice, and you are off to a good start. I do this sort of fabrication for a living and it looks like you had that all planned out. I have already done an enclosure similar to this for a friend in his 4 door. It turned out nice, and sounded great. Keep up the good work; and as someone else mentioned...you're a machine..so many projects lately!![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
![Brows](https://www.jk-forum.com/forums/images/smilies/brows.gif)
Looks good! I used to do that kind of stuff for a living also. I usually used speaker grill cloth for my form material, It soaks in a lot of resin so gets very strong. I like the cup holder too. i would have to mold in a six pac holder for any of my friends!
Davesrb
Davesrb
Well, in-between drying on the snorkle and other projects I put a layer of body filler on one of the Q-forms. This is just the base layer and depending how god this filled in the divits, etc, will depend on how many other coats I need to apply. The final coat will be a mixture of filler and fiberglass to make a "milkshake" that is hard as a rock. I think we are going to paint these with a color matched bedliner type stuff, so I don't have to get it exactly perfectly smooth...THANK GOD..lol
Here is the form taking shape. Now you can see depth in the project and the shape taking place. You can get a better understanding of how this will look in the JK now..
![](http://www.rutdigger.info/S3010099.JPG)
![](http://www.rutdigger.info/S3010100.JPG)
More to follow.
More to follow.
Can you lean the passenger seat back? it looks pretty close when the whole seat is moved back, but are they able to recline?
Great work, amazing detail, you guys need to patent those before somebody mass produces them. Huge hit for 2-door sound fanatics.
Looking good Rut! How many layers of chopped mat did you lay on the front where you used the t-shirt material? If it isn't thick enough you will likely have a lot of resonance from the panel. I might have missed a picture or something with that step, so disregard that question if you accounted for that already. If it turns out that you have some resonance once its done anyways, just use some Hush Mat or Dynamat(premium) on the insides of the box, and pack it with polyfill. It helps the tone of a(mostly) fiberglass enclosure a great deal. Amen on the sanding part !! Thats the worst man!! All in all; it is shaping up nicely, keep us posted on how it sounds!
