My rear bumper build
Old 01-30-2012, 04:20 AM
  #21
itsajeepthing91's Avatar
Took the bumper off to beef things up! The mounting bracket for the bumper wasn't a strong design so when It was put to the test it bent out. The solution we came up with was tie the mounting bracket into the crossmember. Below is a picture of how we did it we made the piece up, drilled the holes to match the factory holes in crossmember, welded nuts on, and welded to bracket.
Had a receiver lying around so figured we may as well incorporate it. We welded a piece of angle iron on to sit on the backside of crossmember and again drilled holes to match factory. The bolts will go through the receiver and crossmember and thread into the nuts on our mounting bracket tying it all in.
First time around I didn't do the greatest job prepping so this time I made sure I stripped it down gave it all a good sand, wiped down, 3 coats of primer, and now am waiting for first coat of paint to dry.
Old 01-30-2012, 09:31 AM
  #22
Final coat
Old 01-30-2012, 09:36 AM
  #23
Tonka_yellow's Avatar
Looks good where you get the shackle mounts
Old 01-30-2012, 09:45 AM
  #24
Got them from my rugged ridge front bumper. Ordered the bumper with the shackles and when I had the extra cash I upgraded to the stinger. I believe you can order the shackles separately from them but I'm sure they probably arnt' cheap.
Old 01-30-2012, 02:41 PM
  #25
Everything bolted on
ID:	272345   Click image for larger version
ID:	272346   Click image for larger version
Quick Reply: My rear bumper build
