My mall crawler- recommendations welcome
#21
Those seats look nice. Ive seen it mentioned a couple places in this thread and thought I should mention there isnt such a thing as a Rubicon spring. There are just different springs for different trim packages. For instance a Sahara and a Rubicon 4 door with dual tops and towing will most likely have the same springs (e.g. 18/58 rated or close to it.).
#22
Thanks pal
Noted, thanks. The springs that came with the Rubi shocks were probably from a 4 door with tow pack because they raised me up quite nicely!
#23
What do y'all think about All terrains instead of these mud tires? These aint too bad, and I've rotated them already at 6k- but All terrains may make the ride alot more mall friendly.
#25
Mud Terrains will need to be replaced 28k - 32k miles.. if you go this route
All Terrains will last you longer and will withstand a bit more abuse.. I've always like the gear argent rubi wheels.
#26
Thanks, Brooklyn, NY is pretty tough on tires. I can usually hack off around 20- 30%% of what typical drivers get on tires (and brakes ) .
#27
Update- the leather seats from Star are holding up nicely.
Happy to have saved the money vs factory leather.
I have finally saved up for Anvil color fender flares and hard top.
Took a year longer than I thought.
LET THE SHOPPING BEGIN!
Any recommendations? Saving money is good- but I don't want to chop the stock fender nor sand and paint it.
Thanks friends!
Thanks friends!
#29
Yeah 34" tires work (305 70 17 on Rubi rims), I have a 1" lift only and they fit even without spacers, tho limits turning radius up front to 1 and a half turns of steering wheel
#30
