My HEMI swap into my '07 Sahara...
#101
Ben----How about giving me a short ride sometime. I live approx 40 miles from you...I go over to Ormond Beach to take my Chemo. treatments---Im planing of letting SL do the 5.7 install on my 08 Rubi in Oct. JUST would like to see what it feels like
Thanks,
Walt
Thanks,
Walt
#103
Sblaine:
I am planning on doing a 6.1 transplant using all new parts, here is what I have listed:
6.1 Hemi..............7500
545rfe.................3000
AEV Premium.......5250
All accessories.....2000
You can easily cut this down by literally thousands, if you use used parts and/or find a donor in the junk yard.
Also, you need a 2.5+" lift to do the swap.....that's what i was told be SLC, so my swap will be including an RE 4.5 LA.
Hope this helps..........
#104
Sblaine:
Can you tell my why they said you need a 2.5" lift? I just had a 6.1L installed in my 2007 2 door Rubicon which has no lft. They put TJ Rubicon springs in front which got my stock height back is all.
Just has me wondering if I am missing something that could cause damage later.
I have not had it off road yet very far (still need engine/tranny skid pans /sigh), but far enough to have worked the suspension some with no visible problems.
It now takes me about 30 miles to make the 8 mile trip home from work. The Jeep just does not want to go back to the barn anymore!
#106
You might have a problem with the drive shaft making contact with the header. You may also have a problem with the upper control arm mount making contact with the oil filter.
#107
Sorry for thread hijack OP.
#108
Ben
