My front Bumper build
Old 08-25-2011, 08:18 AM
metalic's Avatar
Default My front Bumper build
Everything Bent and tacked now finish welding & taking the plasma to it for the winch opening tonight. I'm going to recess the winch and was wondering if I should make a separate plate that mounts to the inside of the frame rail or make it part of the Bumper? I used 3/16 for the bumper and will use 1/4 for the winch plate. Click image for larger version
Old 08-28-2011, 01:00 PM
metalic's Avatar
First mock up on the jeep
Old 08-31-2011, 07:38 AM
taylorthedude's Avatar
It looks good so far. Id like to put a winch in mine also with a similar set up but iv gotta get some money together for a winch first
Old 08-31-2011, 11:19 AM
metalic's Avatar
I got the winch plates tacked in the bumper last night and tonight I will check fit before I weld it solid. Hopefully this weekend it will be painted and installed Click image for larger version
Excuse the messy garage in the background That's called to many projects going at once.
Old 08-31-2011, 02:53 PM
metalic's Avatar
Weld the winch plate solid and paint. Debating whether to bend a light bar over the winch
Old 08-31-2011, 03:47 PM
Lilahs Jeep's Avatar
Very nice!
Old 08-31-2011, 04:29 PM
metalic's Avatar
Originally Posted by ludski
recovery shackles?
I'm actually going to order the bolt on style tonight. Just finished welding the winch plate and bending the hoop
Old 08-31-2011, 04:38 PM
River Runner's Avatar
very clean, the winch sittin low really looks nice, GOOD JOB. It make it so much better when you think about what you want instead of just throwing S*^t together.
Old 09-01-2011, 09:09 AM
Sukkib's Avatar
Looks good!
Old 09-01-2011, 06:27 PM
metalic's Avatar
A Lil more sanding and it will be off to the sand blaster. Then i'll spray an epoxy primer with sem bedliner on top. I ordered mbrp bolt on shackle mounts today. Then more cardboard cutting to design the rear. Thanks for the kind words as it's my first bumper build.
Quick Reply: My front Bumper build
