My Fender Chop
#22
Thanks, um I really REALLY took my time taking everything out and sanding it down, total cut time maybe 10-15 mins both sides but total prep time and sanding about 3 hours. It took me a while to figure out what lines to cut (I had three different patterns) and it also took me awhile to figure out where I wanted to cut the underside support. It's really not hard and if you have a dremel tool you can do this in your driveway (which is what I did) just take your time.
#24
When/If i do my fiance's or anybody else's for that matter I will do an extensive write up. I searched nearly all the threads on fender cuts before I tackled this and all were good up to the point nobody really told you how to effectively take apart the fenders before you start hacking. Once I figured out the passanger side the driver side was a breeze. I actually left everything together on the driver side up until the point that I had made the last cut on the actual fender then I started unbolting and cutting off plastic rivets then everything just pulled out as one.
#26
#28
...just wondering how sharp the edges are....or if you were able to round them down fairly well?
We could set my 1/2 doors on that good look'n rig of yours too...just to see how they look!
#30
