MY CB Install...
BTW, I forgot to mention -- the CB is also a little too wide for the brackets. You have to file off around 0.5 mm from each side of the upper and lower brackets. The lower bracket also has to be modded to slide into the console -- a small triangular piece has to be cut off from the rear. You also have to drill the CB cover and use some small "L" shaped brackets to bolt the CB onto the tray.
Hm. Sounds like I definately need to take some pictures. I should have taken some along the way, but forgot. Oh well...
js.
Just curious
Very very nice! I've ordered the same overheaad console from Tuffy. My CB is smaller though so I don't think I'll have any mounting issues. Did you have any mounting problems with the console itself?
js.
Looks good! Mine is mounted in the same place, although its a bit quiet. My CB Radio manual said to use a 4W 8OHM horn. Is that the same as what you're using? Is there any way to amplify the output and use a louder horn?
js.
Is yours the same way? THat is 75-100% volume knob when on the PA function?
