My Build - Prodigy Performance Turbo
Old 02-21-2013, 07:13 PM
jlb0125's Avatar
Default My Build - Prodigy Performance Turbo
After months of countless hours reading and researching, I decided to purchase and install the Prodigy Performance Turbo Kit. The Jeep is an '09 2 dr 6spd X with a 2.5" lift kit, 33's and 3.21's. I had all the exhaust pipes ceramic coated, and the air intake pipe powder coated. The turbo has a blanket installed to help with the heat. I've put on about 100 miles on the system, and so far I am very impressed with the performance. I have not been stepping on it, as I am trying to break it in. I've also upgraded to Mobil 1 oil and filter. Last month I replaced the differential covers and upgraded to Mobil 1 there as well. At the current time, I am using Torque App on my droid, and I must say that it is pretty accurate. I'll probably use this app for a while, since I've yet to decide as to what gauge or gauges I am going to install. Autometer has a gauge pod that goes over the radio and allows for 3 gauges to be mounted. I also like the Aeroflow gauge, which I would have to install on either the Rugged Ridge A Pillar switch mount, or the sPOD. Time will tell, as this is not a priority right now.
Since you guys like pictures, here are some from the install:
As I mentioned above, I am very impressed with the system, Prodigy Performance, and their customer service. Wes is very easy to speak with, and patient. He has answered every question that I've had, and assured me that the system would perform as advertised. If you are thinking of doing a forced induction system, you owe it to yourself to check out this system. I hope that you guys enjoyed the pictures.
Old 02-21-2013, 07:21 PM
RodRecket's Avatar
Very cool how long did it take you to install?
Old 02-21-2013, 07:35 PM
shockwaveaz's Avatar
How does the low end feel?
Sent from my SPH-L900 using Tapatalk 2
Old 02-21-2013, 07:39 PM
jlb0125's Avatar
The install was done over a span of 3 weeks, working a few hrs here and there in between work and family responsibilities. Overall I would say 20 hrs. We ran into a few issues, not Prodigy's related, which delayed the install. Add to that the fact that both my friend and I are what some call OCD, and well, you get the picture. If we were to do it again, we can probably get it done in 10 hrs or less.
Old 02-21-2013, 07:51 PM
jlb0125's Avatar
Low end power delivery feels smoother over stock. The engine no longer feels like it's going to explode between iddle and 3k rpms on 1st and 2nd. I am sure that if I had taller gears, it would feel even better, but I am ok with my gears for now.
Old 02-21-2013, 11:11 PM
MeMongo's Avatar
That looks awesome. Someday I'll win the lottery and be cool too.
Old 02-23-2013, 12:41 PM
03HDFB's Avatar
NIce Bro.....Now get out and enjoy that ride!
Old 03-13-2013, 08:20 AM
Captaincalf's Avatar
Default Oil feed and drain lines for turbo
I'm looking hard at this system too, so thank you for sharing!
I've got a question that's been bugging me and I should prolly just call them, but if you don't mind please tell us how you plumed the oil feed and oil return lines to and from the turbo & thanks!
Old 03-13-2013, 10:36 AM
jlb0125's Avatar
Captaincalf,
You will need to drop and drill into the oil pan so that you can install the fitting for the oil return hose. The feeder line will be connected into the engine block on the drivers side. There is a screw there that will need to be removed to connect this line. The other end of the feeder line will be screwed on the turbo as shown on the picture above. Pretty simple.
Let me know if you have any other questions.
Juan
Old 03-13-2013, 10:43 AM
Originally Posted by jlb0125
Captaincalf,
Juan
Thanks! I figured there was a pressurized oil outlet somewhere that would be simply a matter of removing the plug and attaching the turbo feed line otherwise it would be too difficult for folks to DIY and the return dumping into the oil pan makes sense too.
What do you think of the tuning step and can you still use your cruise control?
Quick Reply: My Build - Prodigy Performance Turbo
