my 11 Sahara is NOT Trail Rated!! WTF?
Old 03-14-2011, 06:02 PM
speed2005's Avatar
Default my 11 Sahara is NOT Trail Rated!! WTF?
Just looked at my pic and my stomach dropped! Did they change something for 2011? I'm a bit pissed now!!
Old 03-14-2011, 06:03 PM
PatrickESJK's Avatar
What does a jeep have to have to be trail rated?
Old 03-14-2011, 06:04 PM
u-joint's Avatar
The trail rated badge is on the driver's side, not the passenger.
Do you have a t-case shifter, that would be the easiest way of knowing if your trail rated
speed2005's Avatar
I donno but I see a lot of Sports with the badge. FML
wxjeep's Avatar
The badge should be on the drivers side.
speed2005's Avatar
....running out to check
u-joint's Avatar
Only the 4wd versions of the Wrangler of trail rated... so if you see a JK without a trail rated badge either it's owner removed them or it's 2wd.
Old 03-14-2011, 06:05 PM
Aren't all JK's Trail Rated?
Old 03-14-2011, 06:06 PM
Didn't know there are 2w drive JK's.
Old 03-14-2011, 06:07 PM
u-joint's Avatar
Nope... the unlimited X/Sport/Sahara are available in 2wd...
Quick Reply: my 11 Sahara is NOT Trail Rated!! WTF?
