Mudding humor
I don't know if there is a thread, but I wanna bring some humor to the Mudding community.
Muddin' is like sex.. you see the hole, you think about it, you hit it and then you're in balls deep until your motor blows
or ..... you see it and think you really gotta try it out , when you finally work up the nerve and go for it , you find you bit off a little bit more than you can chew . but its too late , your trapped and your rather average equipment aint gettin it done and there is only one thing to do . you call your buddies ..........
I heard when you go muddin' you put on your best rubber and hit the biggest brownest hole you can find and hope when your done that you don't go home with anything permanent!
When you find that perfect mud hole and you just want to get in it, you cant help but get excited and a bit nervous. Key is not start off too aggressive and just floor it, but at the same time you dont want to take forever to get dirty with it. You kinda start off soft to test the water, then once in end up going hard. Afterwards you take pics of the mark you made and show your budds
