Mr A's Prorock 60 install
Sponsoring Vendor
What Dynatrac said, he's matching the front 44's 5x5 bolt pattern.
Sponsoring Manufacturer
8 lug provides a full floating (FF) rear axle although we can also do FF in other lug patterns. A full floating axle handles the weight of a heavy JK much better as none of the vehicle weight is riding on the shaft. The weight instead rides on a very heavy duty spindle. 8 lug also helps spread the load on lug nuts. Each stud carries less weight and there is less chance of failure. We don't see many lugs stud failures but its happened on some obese JKs.
Originally Posted by chris@offroadevolution
He has a rubicon front 44, with a single Evo lever set up
Nice looking rig Mr. A
