Mopar Off-Road Bumper with XRC-8 Winch
I have the same combo of lift and bumper. Only diff is the brand of winch. You will be fine adding a spacer. I recommend a 1" vs the 3/4". I currently have the TF 2.5" + 3/4" Daystar and wish I had just a little more lift. Mine maybe sagging a little more as I have the steel cable.
I'm running 35" tires and at full stuff, still no rubbing. The key is the TF bump stop extensions.
My upgrade will likely be TF 3" coil and leave the 3/4" spacer on there.
How did it fit? Holes line up correctly?
I just ordered a Warn 9.5ti for my existing Mopar bumper. Do I need to remove the bumper to install the winch or can I get away without removing it?
Mopar Bumper w/ fog lights
Where did you get the bumper and how much was it? I really like the look of the bumper and the fact that it incorporates the oem fog lights.
