Mopar Off-Road Bumper with XRC-8 Winch
Old 04-11-2009, 04:19 AM
RedRock GatorRaider's Avatar
Default Mopar Off-Road Bumper with XRC-8 Winch
Just installed the Mopar off-road bumper with and a Smittybuilt XRC-8 Comp winch. The winch came with the synthetic line. Total cost for everything was $950, and took around 4 hours to install.
For reference, I have a 2.5" Rough Country BB. The only thing I'm not happy with is that my rake is now even worse. I'm considering adding a leveling space up front, but since I'm already at 2.5", I'm not sure if I can without having to mod my driveshaft.
Old 04-11-2009, 04:33 AM
Rhino64's Avatar
thats a great looking setup. To me the rake looks about right in the pic.
Old 04-11-2009, 04:53 AM
Thanks. I chose this setup because I like the clean look, and how well the winch set into the bumper.
Old 04-11-2009, 05:05 AM
Rhino64's Avatar
How much difference (lower) is the front? Mine is 1", I think that is about right.
Old 04-11-2009, 05:11 AM
It's a little over an inch. Maybe it's not as bad as I thought.
Old 04-11-2009, 06:38 AM
greenamphibious's Avatar
looks great, you can add a 3/4 spacer with now DV mods needed
Old 04-11-2009, 06:45 AM
Offroadme's Avatar
just wondering i have the same synthetic winch line how did you get the hook on there? did you un strand the line and hook in through then re strand it again i know there was a way to do it just not sure how
Old 04-11-2009, 06:51 AM
PIPES2008's Avatar
first of all, looks great!-second-you'll be fine adding the spacer, all you'll be doing is reclaiming the lost inches you already had with the b.b.-no additional. If by chance you gain a 1/4 or so, there's no dr.shaft probs at all-measure how much "loss" there was by adding the mods, and get the appropriate spacer, ie., 3/4 or 1 in., etc...
Old 04-11-2009, 07:04 AM
It actually came with the hook already attached...
Old 04-11-2009, 07:57 AM
Xtreme RC's Avatar
Looks great. I think the rake looks good also. but i have heard you can install another spacer up front with no problems.
Quick Reply: Mopar Off-Road Bumper with XRC-8 Winch
