mattgt5 2013 JKUR build thread
#211
Not opposed to transferring tpms but since I sold my wheels and tires I am not paying $100 to break them down and mount them back up. Just not that important to me.
#212
#213
I assume you meant enough lift, and the answer is yes the 3.5 is enough for 37 with flat flares. I bought the spacers when I was going to run stock flares. I had them so they went on anyway, hoping to cut an inch out of front bump stop to really max out suspension. May not work, but not hurting anything.
I asked because that is the lift I am about to order with a set of 37" nitto trail grapplers and wanted to make sure I had enough clearance.
#214
You will be good to go.
#215
I like it. I think I can do some adjustments with the rear arms and dial it in a bit better. I also think a new muffler is in my future since the relocated sway bar is basically touching the stock one. Overall I am happy with it.
#219
Here are some pics of the dually and the switches installed.
Attachment 439132
Attachment 439133
Attachment 439134
Attachment 439132
Attachment 439133
Attachment 439134
I've been following your build, loving the choices. I have a set of those 2x2" LED spots coming in, and I was wondering what mounting brackets you used here?
Also, who makes that switch panel there, probably the best looking one I've seen.
