Make you own headliners
Old 02-13-2014, 09:04 AM
  #21
SeverePatronage's Avatar
Originally Posted by lakejeep
Exactly, however you could use thin vinyl just as you said with right amount of adhesive, I feel that headliner material is warmer for winter though and helps with sound better for stereo sound, think about it, studios and theaters use like materials for walls to better sound
The insulation is mostly coming from the foam block. Almost any fabric other than leathers and vinyls will have some R factor. Leather very little insulating properties, and vinyl depends on how thick of a backing it has. Canvas would likely be almost as bad. For insulating properties, I would go with a fleece. It tends to be cheaper than specific headliner materials, a bit thicker, and almost as stretchy and light.
Old 02-17-2014, 05:16 PM
  #22
Oatz328's Avatar
I used a fairly thick synthetic poly fabric from a local fabric supplier. I wouldn't use fleece. It tends to pill if you rub it, ie)taking off the freedom panels. Thinner fabrics may allow the adhesive to soak through as well.
Quick Reply: Make you own headliners
