Made my own Snork!
#41
that is amazing, i was looking into buying one but i think it looked pretty bad. It is all made of steel but its just ugly looking, i would go for something like this instead.
#43
Thanks and the snorkel looks awesome, when its complete let us know on the performance of it.
#44
Question on your HI-Lift on the hood. Does your washer fluid sprayer hit the jack? It looks like you have the Hi-lift up high enough for the sprayer to work. If this is the case what did you use to lift it up?
#49
The Outer prototype is PVC and ABS. Yes.
Once Ive fine tuned the entire snorkel, Ill replace outer with different material., or fiberglass existing to make smooth solid piece.
Although some days I like the rudimentary and industrial look of the Piping.
#50
I like it. Have you thought about swapping the pipes so the intakes on top? That way if any water does get in hopefully it stays in the bottom of the box and not through the filter?
