Made my own Snork!
#31
It's a combination of PVC and ABS, primered, cemented, sealed, sanded, rubberized, then bedlined.
I also ground down any writing, stumps, or nubs that were raised up on the surface of the PVC.
#34
Very nice job, you have to take a look if you can of the australian outback challenge competitors, a lot of them use home made snorkels, and they work very good.
#36
You people.
It isn't worthless.
Just look and say oh, cool.
You only need under hood pics to figure out how to do it. Lol.
That said, I have 3 different underhood prototypes I am trying out over the next month. When I choose which I like the best, I will post pics. ...and, for you beggars, maybe a brief write up.
It isn't worthless.
#37
Ok. Here is what is going on with under the hood.
First of all, I experimented with the following:
1. PVC/abs to filter/ intake
2. flex hose
3. Aluminum pipe and rubber elbows.
What I finally decided on was the following. I am using PVC and ABS to make a perfected template. Then I am going to have 2.5" steel pipe mandrel bent to those specs to allow maximum airflow. Will post pics when all is done.
2. flex hose
#38
That's sick. Obviously the tat business is way too slow in Henderson for you to run all these mods.
I want a pic of the snorkel on, 4 fog lights, and no fenders...
Maybe Andrew can run by so you can install his lift for him before the Sunday Mardi Gras Parade too?
Good work!
Good work!
#40
Good work!
Good work!
Can't give you the pic you want. The front bushwackers are already on. Sorry.
