M.O.R.E. 1" Body lift Installed (pics)
Old 05-24-2008, 05:51 PM
onlyone's Avatar
Default M.O.R.E. 1" Body lift Installed (pics)
I just installed the MORE 1" BL this afternoon. It was one of the easiest mods I have done. Took about 45 minutes. My TJ was easy but I had to either put a motor mount lift on or relocate the fan shroud . I did the MML and that took me a while. With the JK you don't have to do either. The front body mounts need to be replaced, but that comes with the kit. Good instructions and good quality components. Here are some pics.
Before with 18's
Before with Rubi wheels/Tires
After
Old 05-24-2008, 06:16 PM
jeepin08's Avatar
very nice the body lift is hardly detectable
Old 05-24-2008, 06:27 PM
JK-KJ's Avatar
I've never quite understood the body lift thing, so bare with me...I'm assuming you remove the body mounts (how many are there?), jack up the body somehow and then install the little spacer things.....is that right? If so, how do you jack the body off of the frame?
Don't mean to sound stupid, I've done the spacer lift from Rough Country but I've never dealt with the body lft before. Also, how did you do it in 45 minutes? This one says it takes 8-10 HOURS -----> http://www.quadratec.com/products/16047_501_07.htm
Old 05-24-2008, 07:13 PM
mikeyfl's Avatar
manual or auto?
Old 05-24-2008, 07:18 PM
pulman01's Avatar
I had a 1.25" BL on my TJ and liked it. Probably will do one with the JK sooner or later. I have alittle rub at full stuff up front and hopefully that will remedy it.
Old 05-24-2008, 08:42 PM
onlyone's Avatar
Automatic JK.
Loosen all 10 mounts. Take out bolts from drivers side. Jack up body between middle mounts. Insert pucks above factory mounts. Insert new bolts. Repeat on pass side. There are a few other things , but thats basically it. I don't know where they are getting 8-10 hrs. It would have only taken me 20 minutes but I had to take the grill off to replace the front mounts. Those little plastic fasteners that hold the grill on can be a pain in the butt.
Old 05-24-2008, 09:00 PM
ben1284's Avatar
does it come with detailed instructions?? cause i haven't seen a write up on this....or is it just that easy???
Old 05-24-2008, 11:47 PM
aldaman's Avatar
Here are the MORE instructions for a 4dr (less 2 bolts & pucks for a 2dr)...Note ( #11 & 12 uses the two pucks with the 9/16" hole & the 2 thicker bolts if you have an '08...)
Old 05-25-2008, 02:48 AM
JK-KJ's Avatar
Originally Posted by onlyone
Automatic JK.
Thanks, that helps me a little...
porschebreath's Avatar
Any differance in the ride? and is there any body roll or noises?. LOOKS GREAT, I just ordered mine
Quick Reply: M.O.R.E. 1" Body lift Installed (pics)
