LS Engined JK's
Has anyone here ever swap their 3.8 with an LS engine? Would it be a lot easier to swap with a Hemi than an Ls? The reason I'm asking is I am given the chance to buy a pretty new LS 5.3 from my friend for a great price.
Thanks
Matt
Thanks
Matt
as a former LS-junkie, I'm a firm believer that the LS series was the best motor platform.. EVER. the power output of these things is INCREDIBLE, especially with a cam and some worked over heads. I'm just not that impressed with the Hemi motors, if they're so great, how come you never see them at the track? my dad's dodge has had many problems over the years with waterpumps, headgaskets, sensors, etc and he religiously follows the maintenance schedule. I've NEVER had to touch my LS motors other then when i upgraded parts due to wanting more power. The main problem that you'll run into with the LS motor is that you'll have to run a chevy transmission and in turn, a chevy transfer case. i dont know of any adapter kits for a chevy to jeep transmission. it sure would be sweet to have the option to bolt up a 5.7 aluminum block LS6 to a jeep 6 speed manual transmission with the rubicon 4.1 tcase. Actually, my dream build would be a HCI LS6 through a 6 speed, with toyota dual cases with 4.7 gears in the rear case. now that'd be awesome in a 2dr JK.
The GM truck crowd was very interested in the T56 tranny swap behind their LS motors -- BUT, even the 2wd short bed trucks couldn't keep clutches in them, so I'm not sure how well they'd hold up in a wheeled Jeep.
Granted, this is back about 5 years ago when I was also heavily into the LS series engine modding. The truck crowd was pulling the T56's out of the last generation Camaros and Firebirds. And, they were hitting them pretty hard at the track. Clutches may have improved since then.
For autos, 4L80E's can be build to handle lots of power. Even the 4L60/65E's can handle a good amount - I would think up to around 400, maybe 450 crank hp in our rig, and will sap less power.
There is an insane amount of tuning parts available, and lots of standalone controllers for custom applications like street rods and resto-mods..
Check out Jeep Speed Shop - they have been working on an LS swap. They are only offering it as an in house swap now, but they might be able to give you some pointers.
JD
JD
I have LS in one of my JK's it fits in perfectly. If you want smog you will have to go to a professional shop. I've seen other LS and the shop does real nice work.
