Look what just arrived!! Poison Spyder Rocker Knockers with Sliders!!
I'll be installing these bad boys this week to make sure all the adjustments are made then off to the powdercoaters!
I'll also have a full install write-up right afterwards. First impression is that these things are SOLID as HELL!!! They weigh at least 45-50 lbs each and the main bar is solid 1.76" steel. The overall fit & finish is top notch.
UPDATE - Install write-up....https://www.jk-forum.com/forums/jk-write-ups-39/poison-spyder-rocker-knocker-slider-install-4-door-jk-104091/
I'm going to either do red for the outside bars with a black center plate which will leave the spider showing through as red....or the reverse of all that with black outers and a red plate showing a black spider. Part of me wants to rattle can them myself so I can do touch-ups alot easier. But darn, these are good looking!
