lod 3rd gen linked!!!
Old 07-08-2011, 07:46 PM
  #51
sringer's Avatar
It's hard to get good pics with the spare on...and I need to make a few adjustments to the bumpstopping and the cb bracket.
ID:	179778   Click image for larger version
ID:	179779   Click image for larger version
ID:	179780   Click image for larger version
ID:	179781   Click image for larger version
Old 07-10-2011, 08:41 AM
  #52
Yamaha90's Avatar
bump for better pics!
Old 07-10-2011, 04:42 PM
  #53
sringer's Avatar
next time i have the tire off ill get high quality pics. its really hard to capture the awesomeness of this bumper with the tire on.
Old 07-20-2011, 07:07 AM
  #54
sringer's Avatar
first wheelin trip with the lod. didnt get good flexed pics, but i wasnt the photographer. lol
here ya go, they are good pics tho
Old 07-20-2011, 08:36 AM
  #55
sringer's Avatar
Originally Posted by mpkelley20
Ok....this bumper may have jumped to the top of my list. Curious on the install difficulty and time. I know it requires drilling but overall, is the install process hard?
surprisingly it was really easy. you can just set the bumper on the frame on the jeep before you even bolt it...it just kinda slides into place. then take a jack to one corner and make sure its perfectly level. put in all your other bolts then drill the hole. remove the jack then jack the other side. get it level then do the same. it took us 2 hrs...but we messed with the linkage system on the tire carrier for a while to make it perfect. then we spent an our doing fine tuning adjustments on the tire carrier
Old 07-20-2011, 08:55 AM
  #56
JKPier's Avatar
My Lod linked also on the way. Can this be done solo? I did front LoD mid solo but thought this one might be tougher.
Old 07-20-2011, 11:07 AM
  #57
greggnj's Avatar
How was it off road? Any noise from it or anything?
Old 07-20-2011, 10:15 PM
  #58
sringer's Avatar
yes it can...as long as you can lift the weight of the bumper. it helps to have a second hand to line stuff up and make sure your angles are correct. but yes it could be done by yourself
Old 07-20-2011, 10:17 PM
  #59
sringer's Avatar
off road it performed fantastic. super great all around. not a single squeak from anything. honestly tho...because there is not latch like the other style, because it is linked to the tailgate...if you hit a speedbump or a pothole, or a rut type thingy off road...it bounces a little bit with a little "thud" type noise. but it doesnt bother me. i have my tire mounted as far up as possible.
Old 07-20-2011, 10:25 PM
  #60
totdoc's Avatar
do they make a linked version of the shorty?
Quick Reply: lod 3rd gen linked!!!
