Lifted JKU Pics
Lifted JKU Pics
I am considering this set up for my jku:
2.5" suspension lift
1.5" body lift
35" Toyo MT Open Country tires
Lets see pics of setups similar to this one!
1.5" body lift
Just curious. If your are only going to run 35s why add the 1.5 body lift? I just ask as people all have different opinions, but I am running 35s with a 3.5 and they are almost too small 37s would look way better in my opinion. But if that's what you want go for it
Go any bigger than 35s and prepaid to change a lot more than suspension. for clearance. 3.5 is pushing it with out changing everything, driveshaft, steering arms, power steering lines break lines.
3.5" RK with 37" Nittos.
You don't need the bl to run 35" tires.
I haven't had any problems with steering issues. Brake lines aren't that expensive. I'm still saving for a front drive shafts.
I would recommend staying away from the body lift. I did that on my 2010 with a 2.5" and I honestly did not need it to fit 35"s and it made the ride a lot worse.
Don't waste ur money on the body lift.... If u add up what ur getting u might as well just get a 4" coil lift.
I got a 2010 JKUR 4" Skyjacker coil lift and 315/70R17 Goodyear Duratracs (going to 37" MTR next)
