lift and tires
lift and tires
hey, i want to get a 2.5 in lift. but i wont have enough money to get bigger tires for a while. does anyone one have a picture of a 2dr with a 2.5 lift and 29 inch tires? or should i wait till i can afford both
i just ordered the teraflex 2.5 lift and all i have for now is the stock tires. i should be able to put some pictures up this weekend. you might as well just do it one piece at a time so when you have the money you dont have to go install everything all at once. thats just my opinion.
If you plan to keep the stock tires on there make sure you do not offroad with it or you will have problems with the swaybar link bolts hitting the rim because ther there is not enough offset you can fix this by putting on wheel spacers...but i always say do it right the first way and get some rims with the correct backspace for kmc xd rims it is -12 mm offset.
