lift kits
The more you lift it, the more additional mods you have to sooner later like drive shafts.
The magic threshold is around a nominal 2.5". This much lift will allow you to run 35" tires with spending much more money.
The higher you go, the better quality and up to point more complete kit you should choose if you want long term reliability.
Check out kits from Teraflex, OME, Rubicon Express for starters.
Sponsoring Manufacturer
How big of tires do you want to run? A TeraFlex 4" on a 4dr works with 37's, even a 3" with extra bumpstops will work with 37's. Keep in mind that our 2.5" kit on a 2dr is as high as another brands 4".
well I wanted to run 35's and I like the look of 35's with a 3-3.5inch lift, I cant decide on a company though, I still want a good ride on the road but off road I want the performance
