Lets see em, 2 doors only!!!
Old 12-22-2015, 06:43 PM
  #3011
d. gage's Avatar
Originally Posted by JKinBlack
My 2 day old 2016 Rubicon X... <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=631711"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=631712"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=631713"/>
That looks great man! What are you running for suspension?
Old 12-22-2015, 07:09 PM
  #3012
karls10jk's Avatar
2.5" and 37's because I could. It's about all most everyone needs for cruising up and down the road. It's obviously not going off road like that.
Old 12-22-2015, 07:12 PM
  #3013
d. gage's Avatar
That looks awesome!
Old 12-22-2015, 07:26 PM
  #3014
Wrangeler X's Avatar
08 3.5" 37's
Northridge 4x4
Old 12-23-2015, 03:21 AM
  #3015
Jeep Spicoli's Avatar
Old 12-23-2015, 07:17 PM
  #3016
d. gage's Avatar
Old 12-23-2015, 09:03 PM
  #3017
drtyrat30's Avatar
My 15" RK X-factor 3.5 & 37"
Old 12-24-2015, 05:50 AM
  #3018
karls10jk's Avatar
Is that actually for extreme wheeling or more show and light trails? If you'll actually push it then you'll need to trim back your flares and space out the wheels. I had 37's under 2.5" with properly backspaced wheels plus wheel spacers and it would scrub the frame under full stuff.
Old 12-24-2015, 06:49 AM
  #3019
drtyrat30's Avatar
yeah, I just pulled it out of the garage after installing the RK X-Factor 3.5 kit. Welded on artec coil perches in rear and some other stuff. It's still in the building process. I have front and rear ace engineering bumpers that I'm putting on next. Then a set of sliders and flat fenders. Then I'll be adding a pro rock 44 and build the rear 44 also. Thanks
Old 12-24-2015, 07:02 AM
  #3020
karls10jk's Avatar
When you order the axles, go a little wider than standard. The tires scrub on the framerail. I've also got the rk xfactor 3.5" on a 4dr with 37*13.5's and it could even benefit from more trimming. The tires scrub the grill when it's all tucked.
Quick Reply: Lets see em, 2 doors only!!!
