Lets see em, 2 doors only!!!
Old 01-03-2013, 04:58 AM
  #1041
SOUTHERN OFFROAD's Avatar
Originally Posted by hneiper
Thanks for the specs! So you just removed that arm altogether? Not triangulated?
Gives me hope. I'm already in need of proper bumpstops as mine are just a little short.
Not triagulated just removed the pass side upper (still all factory mounts), Rock Krawler has been doing this for sometime with some of their kits so we just decided to test the idea on our JK. No issues thus far running 37's on the interstate at 80MPH! This set up has really impressed alot of people with the amount of flex!
Old 01-03-2013, 05:02 AM
  #1042
Originally Posted by BubbaJK2012
You have no rear sway bar? I know when I go from my rear antirock to disconnecting it. Freeway driving feels pretty washy. Did you have to relocate your rear Trackbar bracket on your frame side to accommodate your rear axle being pushed back? I know it get pretty close to the rear diff cover especially if your running armored covers.
Did you have to extend your rear lower spring perches or cut and angle them as well?
How about extended driveshaft?
Yes, we removed rear sway bar completely, kept limiting the down travel! On highway we really havent noticed it that much (not something that I recommend but it has been done). Rear track bar is really close to rear pass. side spring, the bracket is still in the stock location, what we did was use the RC rear coil angle shims and the RC spring clamps and set the spring forward on the mount. The rear diff cover is close but no contact thus far.
Old 01-03-2013, 05:18 AM
  #1043
BubbaJK2012's Avatar
If you went with an armored cover a person probably have to relocate it?
Old 01-03-2013, 07:44 PM
  #1044
CC07JK's Avatar
Here is the specs:
2.5" Rough Country x-series kit that we have "tuned" for lack of a better term
moved rear axle back about 1"
pass. upper control arm removed
recently added Bilstein 5100s
Moved up rear shock mount about 1.5"
removed rear swaybar
3" front bumpstop
2" rear bumstop
spring clips/retainers front and rear
cut factory flares
cut down factory front bumper
rear EVO d-ring mounts
17" Pro-comp wheels
1.5" Spidertrax wheels spacers
still running D30 up front w/ stock 4.10 gear
we have our own sleeve, gusseted, and trussed D30 housing going in soon
*I'm sure I have missed something
We have been more than pleased at the way this setup rides and performs.
This set up will flex just as much, if not more than any kit on the market but using mostly RC products it doesn't cost and arm and leg.
Rough Country also provides a lifetime warranty on their products.
Thanks! Let me know if you need to practice some of your skills on another jeep... Lol. That looks amazing! I'm already having trouble affording lift, rims and tires alone.... But can't wait to get them done.
Old 01-03-2013, 09:51 PM
  #1045
jayce303's Avatar
Heres one of mine 3 wheelin
ID:	405407   Click image for larger version
Old 01-03-2013, 11:34 PM
  #1046
Rubi-Cons's Avatar
2012 Rubi-Con
Old 01-04-2013, 02:03 AM
  #1047
teamgreen666's Avatar
Originally Posted by Rubi-Cons
2012 Rubi-Con
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=405413"/>
Any photos from the side this looks very good?
Old 01-04-2013, 06:18 PM
  #1048
jackoskate's Avatar
Here is mine, I have had it for 3 days and i LOVE it!
Old 01-04-2013, 06:22 PM
  #1049
EGalv55's Avatar
What color is that? Looks gold but could be the sunset
Old 01-04-2013, 06:24 PM
  #1050
jackoskate's Avatar
It is Sahara Tan, my iPhone didn't capture the color very well. I will be getting my SLR out this weekend to get some good pictures of it
Quick Reply: Lets see em, 2 doors only!!!
