LED light bar mounting and wiring
I installed three Plasmaglow led switches in my stock a pillar for my 50", duallys and 6" rigid sr reverse lights. Didn't want to have to deal with the fitment and color match issues that some have with the rr panel.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=513909"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=513910"/>
I've done this on my last three jeeps. The firewall hole is right there and all the wiring is hidden. A 3/4" hole per switch and that's it. Been happy with it three times now.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
http://www.waytekwire.com/item/46345/
I'd suggest sticking the 20" on the rack pointing forward, 1 6" on each side at 45 degree angles and then one on each corner in the back at 30 degrees. It'll give you full coverage in all angles.
All too often on this forum you see guys with a crap ton of lights and they are all pointing forward. Its great to light up the tree in front of you but what about the drop/ditch/turn beside you?
