LED Headlights
I have them they're ok... If I had to do it over again I'd probably go with the JW speakers. Just some small picky things that I wasn't impressed with. They don't fit perfect out of the box, the pattern is "OK" at best, I've been using them since the first day they shipped and back then they impressed me because I was coming off of the IPF setup which is a huge improvement but over time I've begun to notice where these fall short. They are a lot cheaper than the JW's which is a huge plus but if you've got the cash go for it.
Seen them in person, much brighter LED color and crisper light pattern with no hot spot. I'm agreeing with you that I'm not personally going to dump anymore $$ into headlights and the trucklite's will be fine but I'm not truly blown away by them.
Exactly...$500 is more than I want to spend on headlights! If the JW Speaker LEDs were under $600, I might think about it if, and only if, they do have a new model that doesn't require you to expand the retainer ring.
