LED Headlights
Old 05-07-2012, 07:20 AM
AJAYR's Avatar
Default LED Headlights
Does anyone have the Trucklite LED Headlites? I like the smoked look but wanted to know how they compare to stock.
Old 05-07-2012, 07:23 AM
snags922's Avatar
x2 - I'd like to know before I spend $500 on them. I do like how they look!
Old 05-07-2012, 09:29 AM
totdoc's Avatar
I have them...I absolutely love them. They look very tough installed, and the light output is awesome!
Trucklite actually posted a nice video showing their product vs stock - I would say it is a very accurate representation of how they work. Find it in this post:
Click me!
Old 05-07-2012, 09:38 AM
snags922's Avatar
Click me!
Are they easy to install? I know the directions for the J.W. Speaker LED headlights require you to expand the headlight retainer ring. That doesn't sound like it is easily accomplished. Do the Truck-Lite LED headlights just fit right in, use the adapter to plug them in and you're done?
Old 05-07-2012, 09:42 AM
Redman333's Avatar
Actually the JW speaker headlights just came out with a new model that doesn't require modification to the housing.
Old 05-07-2012, 10:45 AM
JE8154's Avatar
They fit right in total install time is about 20minutes
Old 05-07-2012, 01:15 PM
Blue Fin's Avatar
Plug & Play
Stock:
Trucklight - low & high beam
Old 05-07-2012, 04:43 PM
AJAYR's Avatar
Originally Posted by Blue Fin
Plug & Play
Stock:
Wow what a difference. Thanks.
Old 05-07-2012, 05:16 PM
fadeout's Avatar
I have them they're ok... If I had to do it over again I'd probably go with the JW speakers. Just some small picky things that I wasn't impressed with. They don't fit perfect out of the box, the pattern is "OK" at best, I've been using them since the first day they shipped and back then they impressed me because I was coming off of the IPF setup which is a huge improvement but over time I've begun to notice where these fall short. They are a lot cheaper than the JW's which is a huge plus but if you've got the cash go for it.
Old 05-08-2012, 12:20 AM
totdoc's Avatar
I put some electrical tape on the tabs of the factory trim ring to tighten up the fit, and I had to trim a TINY amount of plastic off the truck lite connector so it would lock into the factory harness. Otherwise, it was completely plug and play. About 20 minutes start to finish sounds about right. No bucket modifications needed.
Quick Reply: LED Headlights
