Just got home from getting some goodies installed!
That's what I thought you meant, but wasn't clear. I installed mine with the crown of the bend facing up. It's pretty clear if you flip it over, with the crown on the bottom, there will be interference when flexing. That is without a relocation bracket like in the prev pic though. I can see where the relocation bracket will alleviate the interference problem, but the adj end is still upside down no matter how you look at it.
Thanks
The track bar bolts to the lower hole in the JKS reinforcing bracket if you have a 4" or lower lift. The track bar and drag link need to be as close to parallel as possible.
