Just dropped off my Rock Hard cage at the powdercoaters!
#72
Yikes. That looks like some serious head trauma for anyone in the backseat for a head-on or rear end collision. Probably not, just looks like it. I like them for the safety factor for rollovers, but it looks like they would limit you on the usability of your Jeep. Can't have it both ways I guess.
Thanks for the pics.
#73
#74
Forgive the question - all those who bought this - but I am questioning the seriousness of this cage.
It seems from the pics and the RH site that the whole thing is pretty well built in the front (even though it doesn't go all the way to the floor), but what about the part where it links to the main original roll bar.
Looking at the original roll bar - it's so weak it's ridiculous... so what's the point of using this cage if the part above the driver's head will come crushing down on the driver when the jeep roles?
What are your thoughts?
#75
I don't think anyone can 100% comment on what will happen with this cage in an accident until one is documented in actual use. But even then the conditions of what happened in the accident will influence how the RH cage protected the occupants.
Also think that the cage is really meant to offer whatever protection it gives, during an off-road accident. In those situations you're usually going much slower than on-pavement so the protection the cage provides is in reducing the cave-in effect that a roll-over brings.
#76
Put it this way, I spent less than $500 to purchase this cage AND have it powdercoated. For that price, whatever level of protection it provides has got to be better than nothing at all. Sure a full cage that ties into the frame, etc will always be better but there really isn't anything else available right now other than custom creations - and those will cost you at leat $1500 in raw steel.
#77
rockhard cage being installed now!
this cage is neat looking once installed especially since i ordered the padding kits but--wow--the installation is some work.
i guess i thought i could just order it, powdercoat it and bolt it in. WRONG
there are some measurements that have to be done at the front doors to drill holes for the 3 button head screws that hold the side bars in--take your time and be precise. i didnt do as good as i would have liked. the template provided is still just an educated guess as to where the holes are behind the panel and i had to enlarge the holes once drilled to get them to line up-did not like that at all but i chalk it up to operator error( me and my drilling skill into spot welds)
also dont like the cutting of the rear pad to install the rear upper brace since there is no way to hold down the flapping fabric once the bar is in place.(my solution is black gorrilla tape until a better solution presents itself.)
now have to find a way to get my t-tops to sit down and seal up without cutting my fiberglass panels up-will probably end up grinding down the endcaps on the upper cross bar to make clearance since that is the contact point-no problems with the rear of panels or back hard top like i thought there would be where the front brace and the rear brace meet and overlap-jeep already had alot of space there.
since it has been raining here all week i cant take my jeep out due to the ttops not sealing up-kinda fustrating but tolerable since i have other transport--a caravan which is not cool at all to ride in.
once i figure out the picture system i will put some up for u to see.
#78
Thumper, that looks just like my Rockhard harness bar and Iggee seats, but This is my only pic
Sorry Texas Trailmaker, you will have to cut the outside forward insides of the freedom tops to clear the Rockhard crossbar clamps, doesnt take much and when you're done, with the freedom tops clamped down, you should be able to slide a postcard around the crossclamp/top areas
Good luck
JIMBO
JIMBO
#79
Have any of you guys noticed that the center of your dash is starting to bow from the clamping effect the 2 vertical bars make? I have seen some Jeeps where it is noticable from the windshiled looking in but you can't see it that way on mine, only from the inside.
#80
That happens if you didn't cut the outside corners of the dash, where the cage verticals BUTT against it !!
If they haven't been notched, the cage plates will combine a lot of inward pressure, especially if you "pulled them together", TO BOLT THE TOPS
JIMBO
JIMBO
