JKUR 2014 Build- YAY!!
Old 02-19-2015, 05:32 PM
  #21
GutlessPhred's Avatar
I haven't yet. But, here shortly I'm going to trim the flares and then hopefully it won't be a problem.
Old 02-19-2015, 06:42 PM
  #22
sea bass's Avatar
Originally Posted by GutlessPhred
I haven't yet. But, here shortly I'm going to trim the flares and then hopefully it won't be a problem. Sent from my iPhone using JK-Forum
Perfect - you should be able to get away with 2" stops once trimmed.
Old 02-26-2015, 06:49 AM
  #23
Little by little it's coming along. Got the TF sleeves and gussets installed up front along with the synergy ball joints. And I'm having them do some touch up work on one of the long arm brackets.
Old 03-22-2015, 08:59 AM
  #24
I finally got the extra shim installed for the rock hard skid. What sucks is the exhaust still comes in contact with the skid and it created a very annoying rattle.
ID:	602537Click image for larger version
ID:	602538Click image for larger version
I put in some washers between the shims and and that helped with the spacing. Sometimes there is still some contact and no rattle like before.
I got my fenders trimmed. They look a little ghetto. Not the straightest lines. Not sure how to fix that now. I'm going to add some door trim and see if that helps. I like the way the jeep looks, but when looking closely it looks kinda bad.
I also bedlined the rear wheels wells. I like that how that turned out.
ID:	602540 Click image for larger version
Old 03-22-2015, 09:02 AM
  #25
Heres more picture. For some reason it won't allow me to add the others to the previous post.
Old 03-22-2015, 09:04 AM
  #26
Old 06-18-2015, 02:23 PM
  #27
Got some more work done on the jeep. Finally got some D-rings. Painted these ones white and got them mounted up. I'm happy with the way they look.
Old 06-18-2015, 02:27 PM
  #28
I also got myself a PSC Bombshell cover. My rear one sprung a leak up in the mountains.
I painted it all up. First did the spider black and the rest of it white.
(I don't know why this picture is upside down, on my computer it is not)
Old 06-18-2015, 02:34 PM
  #29
Here it is painted and mounted up. It is a bit dirty since we went up the mountains last night.
Old 06-20-2015, 07:50 AM
  #30
Got some more work done. Swapped out the factory steering stabilizer bracket with the synergy one. Factory one was hitting my diff.
Quick Reply: JKUR 2014 Build- YAY!!
