JK-Forum WriteUps Mini-Mod Weekend! (very picture intensive)
#21
Just to let you and others know that an antenna has to be attached to the body of the vehicle at the mounting point. The antenna uses the metal of the body to radiate off of. The part you buy and see is only half of the antenna system. A horizontal surface from the base is the best to radiate from. You could help your install by running a wire from the body to the antenna mounting bolts however the antenna also should not be mounted that close to the tub.
If anyone needs further info on general CB antenna mounting, I would happy to email the article I did for a 4x4 magazine.
#22
#25
All the mods look great and the majority are very low buck to boot I will be doing several of the these myself in the future and it was nice to see what the finished product looked like in the pics. Thanks for sharing them with us all
Dave,
Dave,
#28
I'd hate to see what's going to happen if you ever take this rig off-road. With the antenna mounted to the plastic license plate holder I think you'll end up tearing it a new one. Make sure you post pics, lol.
#29
YES! You need to ground that badly. You really should try to get your SWR below 2 on all channels for optimum performance.
#30
Its much better now since I got my FireStik. I'm below 2.5 on channel 40 and below 1.5 on alot of the lower channels. This is without grounding either.
