JK-Forum WriteUps Mini-Mod Weekend! (very picture intensive)
Nice mods. I like the red interior trim to match the body color.
The only thing that worries me is the shovel. Get some sort of straps to go over the clips and secure the shovel in place. God forbid you hit anything, but if you do, that shovel would be wicked evil if it pops out of those clips and becomes airborne.
I'll look into something like that, but I think it should be OK for now. Those clips look cheap in the picture but they're actually very very strong. Its a struggle to get the shovel in them.
Take some hose (black vacum or gas hose) and a razor cut it long ways up the middle and put it on there, it will look factory. Take some pics if you do it.
Did you get your bracket @ Radio Shack?
Lots of great personal paint to make it stand out in a crowd.
Just to let you and others know that an antenna has to be attached to the body of the vehicle at the mounting point. The antenna uses the metal of the body to radiate off of. The part you buy and see is only half of the antenna system. A horizontal surface from the base is the best to radiate from. You could help your install by running a wire from the body to the antenna mounting bolts however the antenna also should not be mounted that close to the tub.
If anyone needs further info on general CB antenna mounting, I would happy to email the article I did for a 4x4 magazine.
I have no clue. I've had it for several years because I used it on my TJ. It was a two piece mount that pinches together around something. I just used this piece since I found a place to mount it too. It was laying around my house when I first used it a few years back.
As far as parking garages, I just have to unscrew the antenna from the mount. Kind of a pain in the neck, but the higher you can get the antenna above the roof the better.
