Jerry can mounts???
Old 01-23-2009, 06:32 PM
JoeBlob's Avatar
Originally Posted by Camp Crocker
Did U make it up the hill? Nice
Lokks like Alabama Red Clay to me!!!
Yep, about 30 of us made it up it. It's actually Georgia red clay but taste the same as Bama red clay.
Old 01-23-2009, 08:38 PM
Hellbound13's Avatar
How did you mount a hi lift to the or fab? I didn't know you could do that?
Also can the or fab be installed if you have AEV corner guards?
Old 01-24-2009, 05:47 AM
Deviant's Avatar
Originally Posted by capt scotty
I have to go with OR-FAB. The fact it was free from JK MAS makes even easier to like
How does the spare tire mount work on the or-fab set up? My rockstars have that center cap, so i assume I couldnt put it on, or are there different mounting choices?
Old 01-24-2009, 07:44 AM
crazynova's Avatar
I would get the OR-FAB, but feel that it is way overpriced like everything else on the JK.
Old 01-24-2009, 08:02 AM
Sponsoring Vendor
Off Road Evolution Rep
serveapurpose's Avatar
Ok well have a good time utilizing that OEM carrier
Old 01-24-2009, 11:53 AM
capt scotty's Avatar
Northridge( OUR FAVORITE PLACE) carries a plate for lugs. I am in the process of cutting up the original mount to use instead of the "T" bar. I already adapted the brake light to work. It really is a well built carrier.
Old 01-24-2009, 02:11 PM
Sponsoring Vendor
CApt. To answer your email you sent me in regards to the bumpstop on the tailgate... I got rid of them when I had my previous bumper set up. The third brake light I tossed in the trash and the T handle switch to a lug style mount was only a consideration. Now that I fabbed my license plate relocation for the T handle I'm good..
Old 01-24-2009, 02:32 PM
meljr's Avatar
There are holes tapped in the carrier just above where the Jerry cans mount. I bought a foot of running threaded rod from the local hardware store
with some washers and wing nuts, cut the rod in half and it was a done deal.
Yes, you have to install the AEV corner guards first because the OR-FAB carrier installation will
require drilling through the driver side corner guard and I had to grind around the AEV hinge recess
on the passenger side to allow for the heavy duty OR-FAB hinges.
Old 01-24-2009, 03:35 PM
Thanks, any pics of where you grinded the hinges?
Old 01-24-2009, 04:14 PM
meljr's Avatar
It was a raised lip between the tail light and the hinge recess. The lip would cover the fixed side
of the factory hinge, but the OR-FAB hinge is larger and would not fit under the edge of the lip, so
I ground it back until the hinge would clear. Not that big a deal and you wouldn't notice if I didn't
mention it.
-meljr
Quick Reply: Jerry can mounts???
